all turn signals flashing horn not working
Old May 31, 2007 | 07:42 PM
bobbie53's Avatar
Default all turn signals flashing horn not working
I have a 2000 Silverado and have never had any problems up until now. My turn signals are flashing rapidly, all four flash when using either left or right. Which ever signal I am using is flashing faster than normal and is bright, the other one is flashing faster but is not as bright. Now my horn does not work and my windshield wiper water pump is not pumping (it is full). I have checked fuses and all related fuses are good. Any ideas?
Thanks
Old May 31, 2007 | 08:22 PM
Argon's Avatar
Default RE: all turn signals flashing horn not working
All unrelated I imagine...have you "repaired" anything on the turn sigs lately?..a wrong (or backwards) bulb will cause such...or a shorted socket.
Old May 31, 2007 | 08:32 PM
bobbie53's Avatar
I have not changed or replaced anything. Thanks
Old May 31, 2007 | 09:28 PM
smoke20's Avatar
Sounds like a ground issue to me. I know I have the same issue on my boat trailer which has a bad ground, so I would look for a gound issue first. I agree with argon that all your issues may be unrelated, but look for ground issues first, especially in the fuse boxes, and engine ground. Another thing to check is your trailer harness arcing (if you have one).
Old Jun 1, 2007 | 04:58 AM
Argon's Avatar
note if any one bulb is not working or very dim...that socket is probably messing up the works
Old Jun 1, 2007 | 08:09 AM
bobbie53's Avatar
I forget in my original post to say this is an intermittent problem for about three weeks with the turn signals, they might work at one turn and the next they won't. The horn and windshield water pump I just discovered yesterday trying to see if other things were not working. I checked the cruise control and it works, as I thought maybe it was the turn signal itself and maybe the horn was a separate issue. Since everything seems to be localized to the steering column, could it be a wiring problem? Thanks for all the help.
Old Jun 1, 2007 | 10:18 AM
Argon's Avatar
I still doubt it..horn fuse is good?
any power to the washer pump?
Old Jun 1, 2007 | 01:25 PM
bobbie53's Avatar
Horn fuse is good, have not tried a new relay. There is power to the washer pump.
thanks again
cobrajocky
Oct 25, 2012 12:40 PM
will3387
Jan 15, 2010 10:10 AM
r in colorado
Apr 25, 2009 07:46 PM
Lovemydiesel
Jan 24, 2009 07:07 AM
daryl
Sep 10, 2008 04:32 AM
