Argon, update on old post....
Old Jun 18, 2008 | 12:38 PM
jcbst12's Avatar
Default Argon, update on old post....
Remember the Geo? Fuel pump won't prime when switched to the "ON" position, therefore the car will not start. No pressure in the fuel lines either. Signal from starter to ECU is good on the fuel pump relay and there is power to powerwire (red and black wire) an the relay as well. Ground seems good.
Ok, so I checked all the wiring on the Geo for the fuel pump and fuel relay. All seems fine. Pump definately works, relay seems good but there is no power from the ECU to the relay. (Therefore no power to trip relay and send power to fuel pump) According to GM manual there should be power from the ECU when the ignition is turned "ON". Rumor has it the engine light will be off when the key is in the "ON" poition if the ECU is bad. Light is on in this case. PNP seems to be working fine. Think my ECU is dead?
Old Jun 18, 2008 | 06:23 PM
Argon's Avatar
Default RE: Argon, update on old post....
well..bad pcm's are rare..but it happens..
can you get scan data?...a couple things COULD inhibit the pcm from turning fuel on...like theft codes..also,a wide open tps sensor reading will turn fuel off..try and start your truck with your foot alll the way to the floor on the gas pedal and you'll see what I mean.
Old Jun 19, 2008 | 07:44 AM
jcbst12's Avatar
Well I can get the codes maunally and look them up on the web. Or do you think I should just bite the bullet and get a scanner?
Old Jun 19, 2008 | 02:53 PM
Argon's Avatar
not for a jizm,i would not..its too diffrent than regular gm..i might would check the tps with a voltmeter..it should have a varying 5 volt rference...about 1 volt closed,to about 4.9v wid open throttle
Old Jun 20, 2008 | 01:30 PM
jcbst12's Avatar
I'll get on that tomorrow. Thanks
Old Jun 23, 2008 | 06:46 PM
jcbst12's Avatar
Ok, When testing the TPS with a multimeter I get:
Red: Power
Black: Ground
WOT Closed
Yellow: 5.04V 5.04V
Green: 3.84V 0.64V
Am I ok? If its not the TPS, anything else to check before I search for a ECU?
Thanks Argon
Old Jun 24, 2008 | 04:44 AM
Argon's Avatar
looks good..but make sure that green moves with the throttle...up close to 5v wide open..then,its probably ecu time i'd guess
Old Jun 24, 2008 | 08:06 AM
jcbst12's Avatar
Yeah it fluctuates with the movement of the throttle. Someone told me to recheck wiring between the ECU and relay, then the relay and pump with an OHM meter. After that I need to disconnect the battery, unplug the ECU, plug it back in, reconnect the battery and try it again. Sound legit?
Old Jul 14, 2008 | 07:30 AM
jcbst12's Avatar
Ok Argon I need your help again. I replaced the ECU now (got it cheap off of craigslist). The car still will not run. I doubt that both ECUs are bad so I don't know what else it could be. I have a theroy, sort of. I put some more gas in the tank and after trying to start it, I noticed that despite my repairs to the fuel spout and fuel lines that there was still a leak from the filler tube to the tank. Would a loss of pressure in the tank prevent the car from starting?
Note: The pump will not prime again. I made a jumper for the pump relay and it would prime when the ignition turned to "ON" position. When I cranked the engine however the pump would stop.
If not the pressure cause the pump not to run, maybe a ground for the starter signal?
Thanks again!
Z71TwoTone
10
Dec 21, 2007 04:00 AM
chevyrules
Sep 24, 2007 05:42 PM
hunt4game29
Sep 10, 2007 10:44 AM
mls57jax
Mar 3, 2007 01:24 PM
stash
Oct 25, 2006 07:14 PM
