Blowing hot air from drivers side
Old Aug 13, 2007 | 09:26 PM
fishfreek's Avatar
Default Blowing hot air from drivers side
I have a 2004 that in the last 6 months or so has started blowing hot air from the cabin a/c on the drivers side. When it does this it continues to blow nice cold air from passengers side. This happens once a day or 20 times a day. No rhyme or reason. Any help would be great.
Thanks, D
Old Aug 13, 2007 | 09:31 PM
racethisz71's Avatar
Default RE: Blowing hot air from drivers side
it can be two things the bled doors inside can be broken and letting the hot air through or the acutator for the blend door can be bad or needs to be calabrated if the controls are electronic there is a diaignosis setting tell you whats bad
Old Aug 14, 2007 | 04:32 AM
Argon's Avatar
It needs a left temp actuator...pretty common failure these days
Old Oct 27, 2007 | 03:27 PM
usbrowns's Avatar
Left temp actuator was bad.
Old Dec 13, 2007 | 03:43 PM
usbrowns's Avatar
You were right on!
bgwalt37
Jul 25, 2012 10:23 PM
Carter56
Dec 13, 2007 09:35 PM
cride
12
Nov 29, 2007 07:56 PM
SouthBayZ71
Jul 27, 2007 08:21 AM
jonesdg
Jan 6, 2007 08:23 PM
