Checking error codes
Old Mar 31, 2012 | 10:29 PM
95plugwire's Avatar
Default Checking error codes
I have a 95 sierra with the 350 5.7L
My question is am I able to check for codes by cycling the key x amount of times? or is there some other way? without using a code reader...
I searched and to no avail could I find somthing simillar to this.
Thanks in advance
Ah....... why not! Ive attatched a picture of the rig.
Its gotsome damage on the driverside front clip.
Old Apr 1, 2012 | 02:01 PM
TMW's Avatar
TMW
You can read the codes by jumpering pins A and B on the data link connector under the dash on the drivers side. It may have a cover on it. You really have two choices 1- get a copy of the Chilton or Haynes manual for your year of truck and it has the codes in it. When the pins are jumpered the check engine light will flash and repeat itselt on a regular basis. 2-take it to a auto parts store as many will read the codes for you for free. Cycling the key on/off may simulate a start cycle (I don't really know) and that resets the code memory after 50 times, so that may not be a good ideal.
Old Apr 10, 2012 | 04:55 PM
Big_Country09's Avatar
yea easiest way to go about it is go to most any auto parts store and they will read the codes for you. then you can either look them up their or you can get on the internet and find out what they are.
Old May 9, 2013 | 10:35 PM
hellozaizai's Avatar
Banned
without using a code reader????????? unbelievable
if you want to reader error code i think you need code reader
Mike Sigmond
Apr 7, 2009 11:19 PM
chefd
Apr 2, 2008 11:13 AM
chefd
Mar 25, 2008 04:36 PM
wade
May 5, 2007 10:21 PM
Cozmo
Oct 1, 2006 06:14 PM
