Chevy 1500 Lacking power
Old May 15, 2011 | 04:43 PM
JoshLikesBeer's Avatar
Default Chevy 1500 Lacking power
I just bought a 1998 K1500 5.7 L. The engine seems to be running smoothly, but its def. lacking power. I removed the cat, and it helped but its still lacking. My next move is to replace the fuel filter, and check the plugs.
Any other suggestions?
Old May 15, 2011 | 05:28 PM
Check fuel pressure. Are you getting any service codes? I recently had a 1998 that had a bad shift solenoid in the trans and it was lacking power to say the least! It set off a code though.
Old May 15, 2011 | 05:37 PM
cubpak89's Avatar
check your plugs wires and distributer my 94 lacked power before i sold it i replaced everythin plugs wires and distributer cap everything ran smooth also check the fuel pressure as shamrock said to do
Old May 22, 2011 | 04:08 PM
I changed the plugs, and I can notice the difference, but its still not where it should be. Fuel pressure is at 57 psi. From what I understand it should be between 60-66 psi......would three pounds make that much of a difference? There are no codes present
Also, there was a bit of oil on the threads of the plugs. The guy at autozone said its not that big of a deal as long as its just on the threads. I'm gonna check back in a few days and see if/where theres any oil on the new plugs.
Thanks for your help
Old May 22, 2011 | 04:13 PM
3 lbs isn't enough to make a difference IMO. Others swear it has to be at least 60, but I have had numerous trucks that ran at 55-60 and they ran fine. Did you give the cap and rotor a look?
Old May 22, 2011 | 04:21 PM
cubpak89's Avatar
so if the shift soliniod in the trans is goin bad it can cause the same symptoms as my truck spits and sputters too at idle then when im driveingit will try to bog down but i put the gas down and it goes ok after that
how can you check the soleniod and how much does a typical one cost
my trucks a 94 4wd ext cab 1/2 ton
i am trying everything to get it to work
i replaced the wires and coil also replaced teh temp sensor thats close to the coolant inleton the top of engine
i will be replaceing the plugs soon
also i will be taking the cap of fto inspect the rotar as the cap looks new but i doubt the previous owner did a proper job as he should have replaced the rotar under there when he changed the cap
Old May 22, 2011 | 05:40 PM
Thats my next move. I'm on a limited budget so I've only been able to do one thing at a time
Old May 22, 2011 | 08:05 PM
cubpak89's Avatar
im also on a limited budget so i am also takein things one at a time
mjobie12
Feb 19, 2011 01:38 AM
LoudNF
Nov 28, 2008 11:26 AM
Eddie
Dec 1, 2007 12:55 AM
AKcam7
8
Aug 15, 2007 11:34 PM
wyldeman
Jan 19, 2007 07:35 PM
