Couple of problems
Old Nov 22, 2009 | 04:16 PM
klean63's Avatar
Default Couple of problems
I have a 2004 1/2 ton crew cab. It's given me 75,000 trouble free miles but now I have 2 problems I've been trying to chase down to no avail
1st is the rattle in the steering column, at least that where I think it coming from. I'm not refering to the intermedite shaft clunk. This is a rattle. I've looked under the dash for something loose but can't find anything. It feels like it's in the column somewhere but I have no idea what it could be.
2nd, my blower motor stopped working on a couple of speeds a few weeks ago. Based on what I researched, the blower motor resistors commonly go out on these trucks so I replaced it (the harness was fine with no signs of melting). Now it's stopped on a speeds and I found the 30 amp fuse on the side of the dash was blown, which I replaced. It lasted about a week and blew again, replaced it and it lasted about 1/2 a day.
I'm thinking it might be the fan switch but I'm not sure.
Any help would be greatly appreciated.
Old Nov 23, 2009 | 07:09 PM
SlimJim's Avatar
No idea on the rattle. You may just have to take the cover off the column and take a look. I think the fan motor uses a relay on the highest speed. When does the fuse blow.....when changing speeds.....on any particular speed or at random? Any more symptoms you can give will help.
Good luck.
Old Nov 27, 2009 | 07:27 PM
klean63's Avatar
The last time I replaced the fuse it was on low speed when it blew. In fact I rarely use anything except the 1 & 2 position on the fan speed.
Old Nov 28, 2009 | 02:59 PM
SlimJim's Avatar
Check out post number 4 in the sticky at the top of this section. Mr. Shamrock may be able to help you with a solution.
https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/common-chevy-gmc-issues-9726/
I've seen something in here about your rattle also. If I find it again, I'll post it.
Old Dec 4, 2009 | 10:05 AM
klean63's Avatar
https://www.truckforums.com/forum/showthread.php?t=9726
Thanks Slim, I'll look into that.
JDOGG
Jul 26, 2011 11:21 AM
i3oosted
Nov 29, 2010 12:47 PM
Erik G
Oct 15, 2009 12:23 PM
bpsilverado03
May 5, 2008 07:03 PM
LightningStrong
11
Sep 24, 2007 11:08 AM
