custom tune
Old Aug 15, 2007 | 09:20 PM
smoke20's Avatar
Default custom tune
I know several of you have gotten your tunes done already. I am planning on getting mine tomorrow. Can you tell me how aggressive you were and the gains you have gotten, as well as anything you would have done differently?
Old Aug 15, 2007 | 10:42 PM
07_Bowtie's Avatar
Default RE: custom tune
I just want to know if getting a custom tune has anyone been able to break their tires loose after getting rid of the torque management.
Old Aug 16, 2007 | 12:46 AM
BlackHorse99's Avatar
i welded up my rear diff the other day on my 99 angot them to spin, i plan on putting the tune in tommorow
Old Aug 16, 2007 | 01:04 AM
chevy112488's Avatar
ORIGINAL: BlackHorse99
please explain... i heard people used to do that to old cars, but im still unclear as to what exactly is welded?
Old Aug 16, 2007 | 10:38 AM
took the diff out and welded the spider gears across where the teeth come together and took all the gears within and welded them to the carrier itself, all i can say is keep on welding keep om welding to make it strong enough, i only did it so i could move the thing, as the rear end had blown up, now i have a new one in. Oh yeah, when your welding make sure not to weld for too long and to take breaks between as to not heat up the bearings. When your done though it is basicly a spool rearend if you do it good enough. My 99 must not have that torque deal on it, cause it was spinnin
Old Aug 16, 2007 | 08:42 PM
smoke20's Avatar
I put in my new computer and HOLY ****!!! This truck is fast as hell!!! I can't stop spinning the tires. The 0-60 is down to 4.8 sec. I can't believe it.........................OK, I was just hoping. I just ordered the computer so we will see. I ordered the tune with moderate shift firmness normally, heavy firmness at wide open throttle, 200 mph speed limiter, heavy torque management removal except moderate when in tow haul mode, and speedometer recal for tire height. I will let you know the results.
Old Aug 16, 2007 | 11:49 PM
SouthBayZ71's Avatar
Congrats bro ...looking forward to hearing your results.
Old Aug 17, 2007 | 06:37 PM
MrLM7's Avatar
I got 60% of TM removed, 91 octane tune, pin #42activated, put my LS1 fans in, increased firmness at wide open throttle, and had the speed limiter removed... HAULS ***!!! If I am cruising at around 26-28 MPH, and punch it, it will pin my head to the seat... I'm going to the track tom. night, and i'll post my new times...
southcomfort09
12
Jan 15, 2008 03:59 PM
SouthBayZ71
13
Aug 10, 2007 02:27 PM
topknotch06
Jul 3, 2007 06:59 PM
hunt4game29
8
Jun 30, 2007 10:38 PM
smoke20
Jun 18, 2007 04:47 PM
