egr valve or egr solenoid problem
Old Apr 17, 2012 | 12:12 AM
95gmcss's Avatar
Default egr valve or egr solenoid problem
hi need a little help my truck is starting to act up i have 95 gmc sierra 350 tbi. when i start the truck in the mornings revs up to 1000rpm and stays that way even when its warmed up but when i put it in gear it drops down to 8 or 700 rpm s normal i think but when i take off slowly or if im driving in high speeds and let of the gas just a little it feels like it not getting enough gas or like if its missing or hesitates , but if i give it some gas it drives fine so i disconnected the hose going from the egr solenoid to the throttle body and the hesitation,missing or whatever went away except for the idling high and of course the check engine light comes and goes so not sure if its the egr valve or solenoid. any ideas i would really appreciate it, thank you
Old Apr 17, 2012 | 06:32 PM
chevychase's Avatar
On the high idling check for vacuum leaks . Throttle body gasket .
Maybe the tps/ throttle position switch located on passenger side of throttle body. Or a bad coolant temp sensor located beside the thermostat housing.
Need to scan for codes.
Old Apr 17, 2012 | 10:01 PM
95gmcss's Avatar
thanks ill go ahead and check that out
Old Apr 25, 2012 | 03:18 PM
95gmcss's Avatar
Default idling problem
I got a 95 gmc pickup 5.7 when i start it it idles at 1400 rpms for a few seconds then it drops down to 1000 rpms which i think its still to high but when its in gear it idles at 800 rpms just replaced the egr valve and check for vacuum leaks and its all good need help figuring it out, any ideas would help thank you.
klr650goldwing
Feb 11, 2010 11:24 AM
pear69
Feb 7, 2009 05:30 PM
99Sierra
Nov 28, 2008 10:10 AM
72charger
Oct 6, 2007 05:22 AM
sueb
Aug 14, 2006 07:07 PM
