Electric Cutouts?
Old Oct 27, 2011 | 10:02 PM
  #21
RUFFNECK4LYFE's Avatar
Originally Posted by void.pointer
Is the part on the left the ory pipe? So it just bolts on to the headers? Does it bolt onto the stock headers like that too? What connects onto the other end of the ory pipe?
Everything is straight up bolt on. Even if you only got the ORY it will bolt up.
  #22
void.pointer's Avatar
Originally Posted by RUFFNECK4LYFE
There is a flange behind the cats and in front where it connects to the manifolds. Here is a pic of my headers before installation...
Old Oct 27, 2011 | 10:11 PM
  #23
And what goes on the other end? The cats? I thought the cats were welded on.
Old Oct 27, 2011 | 11:11 PM
  #24
Bolt on, everything is bolt on I say again.
Old Oct 27, 2011 | 11:16 PM
  #25
Ok. I just wanted to make sure. I'll get under my truck and map everything out. When you installed your setup, did you use a lift? All I have is a jack
Old Oct 27, 2011 | 11:19 PM
  #26
Yeah just jacked up a little. Soak them bolts with spray lubricant for a few days. Taking off the factory stuff is the hard part. Everything else is cake. Remember disconnect ur battery! Passenger side headers are real close to the + cable so gettin them in there you have a chance of arcing it, like I did.
Old Oct 27, 2011 | 11:29 PM
  #27
I wasn't planning on headers but I guess I should?
Old Oct 27, 2011 | 11:34 PM
  #28
Up to you.
learpilot
May 17, 2011 04:05 PM
sf4037
Feb 28, 2006 10:54 PM
radioflyer
Oct 18, 2005 02:51 PM
mbevington
Sep 15, 2005 11:34 AM
DweeLer
Aug 17, 2005 02:51 AM
