engine swap?
Old Jan 19, 2006 | 02:43 AM
bfekid's Avatar
Default engine swap?
i bought a 90 silverado 2wd 1500 with a blown motor and i was wondering if anyone has transplanted that engine with an lt1 from a trans am or impala ss ? if so could you give me advice on what computer stuff needs to be done..
Old Jan 29, 2006 | 10:36 PM
ckcrazy's Avatar
Default RE: engine swap?
i was going to do the same swap but opted for a TPI motor instead,if you dont have the original key for the car you need to bypass the Vehicle Anti Theft System(VATS) on the ECM or the motor wont start, you can buy a VATS bypass chip, or you can just go all out and buy the painless perfect engine management wiring harness that includes the computer, all you have to do is hook up your ignition, but your looking at a 1200-$1500 wiring harness. and if you cant afford the harness i say just get every last sensor, fuse and wire out of the original car and label everything before you take it out, get everything and if possible get the key and steering column as well. doing a motor swap like that takes a long time and it gets very frustrating..so good luck!
Old May 31, 2006 | 08:19 PM
COSilverado's Avatar
BFEKID,
If you're still in the market for an engine drop me a pm.
How about a low mileage 5.3L vortec with 4L60E trans?
By low mileage I mean about 20 miles on each.
They come with wiring harness + comp., alternator, a/c comp.,
fan and air intake assembly, starter and headers.
All factory equipment for less then you'd expect.
RacerX
9
Mar 8, 2015 04:39 PM
justind
Apr 15, 2009 09:05 PM
cowboyfulton
Jun 21, 2005 10:01 AM
cowboyfulton
Jun 13, 2005 03:41 PM
duramax14
Mar 23, 2005 12:33 AM
