Engine Trouble?
Old Mar 14, 2011 | 11:10 PM
scorecardup's Avatar
Default Engine Trouble?
[redacted]
Old Mar 15, 2011 | 05:14 PM
honestblades's Avatar
Member
Head gaskets go out.... Especially if the truck is 26 years old. All you have to do is fix the head gasket. I'm assuming that you pulled over when you started to see the temperature rise? If you didn't,then you may now have a warped head. Putting a "bigger" engine in the truck has nothing to do with fixing the problem. Eventually head gaskets blow,regardless of how big or small the engine is.
Old Mar 27, 2011 | 05:10 PM
[redacted]
Old Mar 27, 2011 | 07:34 PM
Originally Posted by scorecardup
. More specifically, should the rear end have been modified when the lift was put on?
Thanks again in advance!
Your pinion angle should have changed in the lift.
Acceleration issue... Does it sound like the engine is under a load? Is this why your not getting the acceleration? Or a fuel supply issue ie: pump, filter, pinched fuel line.
Old Mar 28, 2011 | 08:13 PM
[redacted]
Old Apr 3, 2011 | 07:03 PM
[redacted]
Old Apr 3, 2011 | 09:47 PM
Silverick's Avatar
The problem may be that there isn't any compensation for the 35" tires in the differentials.
With the large 35" diameter tires and the assumed standard differential gear ratios, the 305 may not have enough power to pull the truck.
The fix may be to change the gear ratios to a lower (higher numerically) ratio to make up for the tires.
If this is the case then, yes, a bigger engine could make a difference, with the standard gear ratios.
Old Apr 4, 2011 | 01:55 AM
RUFFNECK4LYFE's Avatar
Any more than 32" get 4.56's, less get 4.10's. This will help alot!
Old Apr 4, 2011 | 07:29 PM
[redacted]
jumpinfarmer
Nov 8, 2008 09:11 PM
MRC Chevy
Aug 12, 2007 10:57 PM
iwantahemi
Apr 22, 2006 11:30 PM
klrjoe
Dec 7, 2005 05:32 PM
Cindimccs
Mar 19, 2005 12:56 PM
