Evap and MAF Low Input Codes!!!!!
Old Sep 8, 2009 | 09:11 PM
RUFFNECK4LYFE's Avatar
Default Evap and MAF Low Input Codes!!!!!
Just thought I would share some info! I had my CEL come on and pulled the Purge Solenoid and MAF Low Input codes. Well I thought it was my Evap set up goin bad so I looked for corroded wires and vacum leaks. I checked the wires to the MAF sensor and all good. So I couldn't figure it out and just left it. Been like that for 2 months. I just now read a forum where someone had the same problem and come to figure out, IT WAS A BLOWN FUSE!! Lol The power wire goin to the MAF sensor and the Evap share the same fuse. All this time I thought was chain of problems and turned out to be a busted fuse. I figured it happened cuz I ran a 3rd e-fan for the A/C condensor and put more load on the system. I also noticed when the e-fans come on, the voltage output from the IAT inside the MAF sensor drops about .5 volts. Something to think about when wiring e-fans. I use power straight from the battery with a toggle switch to run the e-fans. Oh and this link to a forum provides a wiring diagram...http://www.grandprixforums.net/f81/m...help-3786.html
TAD
May 4, 2012 12:18 AM
cnewbold
Oct 11, 2009 09:41 PM
Fuzzdawg
Mar 27, 2009 11:00 AM
rxsteven
11
Jun 3, 2008 07:41 AM
silverado_ia
Jun 14, 2007 11:02 PM
