guess what the problem was with my truck
Old May 22, 2011 | 05:22 PM
cubpak89's Avatar
Default guess what the problem was with my truck
well my truck runs great
guess which problem it was
a( throttle body needed cleaned)
b( idle air control valve)
c( the truck is a piece of junk)
d (the gas was low)
e ( the throttle cable
and the answer is b the idle air control valve
i unpluged it today after a friend had suggested i do that to see if its bad
and guess what i drove it 3 blocks with no prblems the only difference is tha tit idles at 2000 instead of the noraml 1000 where it should be
so i plugged it back in and guess what runs like crap
so friday i will be replaceing it
Old May 22, 2011 | 05:38 PM
glad to hear you fixed it! Would that explain why my truck surges when idling in drive or reverse? it alternates between 400 and 700 rpms.
Old May 22, 2011 | 05:48 PM
cubpak89's Avatar
posibly take off your air filter from teh tbi then remove the cable from the idle air control valve the valve is on the passs side and is brass in color it will have 4 pins on it
remove it drive it around the block to see if there is a difference
if so that would be it also it will idle higher in neutral and park at around 2000 as mine did so i am in the process of buying a new one
also make sure you put your air filter back on before you drive it lol i almost forgot
also i am thinking of leaving it unpluged until i can get a new one and i dont knwo what it will do long term to it but i think it would just use more gas
Old May 22, 2011 | 05:52 PM
cubpak89's Avatar
i will be posting pictures of what it looks like later
on my profile pitrues
Old May 22, 2011 | 06:15 PM
cubpak89's Avatar
i posted a picture of the idle air control valve on my profile pictures if ya want to see where it is
Old May 22, 2011 | 07:36 PM
Unfortunately I didn't realize your truck had the older TBI engine in it... not thinking. Mine is the Vortec V8 that has a TPS idle control instead of the Idle control valve. Oh well, thanks for taking the pictures.
I remember fixing that exact same PS hose on my 92! It was a nice little 8 dollar fix
Old May 22, 2011 | 08:02 PM
cubpak89's Avatar
its ok some one one day will be looking for it so its there to stay and as far as the tpi idle goes im not sure about that but i do know if you run your truck under half a tank alot the pump gets over heated as the gas keeps it cool
cubpak89
Jun 21, 2011 06:23 PM
BirdDooHead
15
May 17, 2011 11:50 PM
smoke20
Nov 13, 2008 09:49 PM
72charger
Oct 30, 2007 11:25 AM
bajatuner
Jun 5, 2007 08:27 AM
