Heated seats
Old Mar 31, 2010 | 06:02 PM
1BIGGN's Avatar
Default Heated seats
The seats turn on still but for only 5-20 seconds and then they shut down before they have a chance to warm up. Anyone know how to fix this?
Old Mar 31, 2010 | 08:37 PM
Best case scenario - circuit breaker needs to be replaced
Worst case - the heaters need to be replaced
Old Apr 1, 2010 | 05:38 PM
1BIGGN's Avatar
thanx Shamrock, looked in owners manuel and only found a fuse replacement for heated seats. The fuse was O.K. Where will I find the circuit breaker at? I don't think it is the heater because both seats turn off after about 15 seconds.
Old Apr 2, 2010 | 06:58 AM
What kind of truck do you have?
Old Apr 3, 2010 | 06:05 AM
1BIGGN's Avatar
2003 Chevy Silverado 2500 HD LT Duramax Diesel
Old Apr 3, 2010 | 07:43 AM
Ok let me do some research on how those are wired and I will get back to you.
Old Apr 3, 2010 | 06:11 PM
acnas's Avatar
One of the elements probably has high resistance (burn spot). Seen it many times. Could be lower or back or both elements.
1. Disconnect the seat heater element connectors.
2. Using a DMM measure the resistance through the seat heater elements. Refer to Circuit Testing in Wiring Systems.
Are the measurements within the specified values?
1.5-5.5Ω
If not replace the inoperative heated seat element
tasutt2009
Feb 4, 2011 10:20 AM
easydoesit28
Feb 2, 2011 12:53 PM
sonsofmerlin
Nov 2, 2008 10:35 AM
jaxspellinar
Sep 14, 2007 09:11 AM
mmcosby
Jan 9, 2007 02:58 PM
