Help 2002 Silverodo
Old Oct 4, 2010 | 10:31 AM
Jim Rodman's Avatar
Default Help 2002 Silverodo
I have a 2002 Silverodo HD, and there are two issues’ with it.
The first is the “CRUISE CONTROL “dose not work.
The second is that the “ TOW HAUL “ is not working as well.
If any one here can pass on some info on how to fix these problem
It would be of great help.
Thanks in advance.
Jim form Ontario
Old Oct 4, 2010 | 11:31 AM
RUFFNECK4LYFE's Avatar
The Tow/Haul not working is common simply because the wire in the column will get cut from the manual gear selector. Look near the key cylinder and find an orange wire. You will find it cut by the gears. There is 2 wires inside the orange insulation. Connect them both and voila!
Old Oct 4, 2010 | 05:49 PM
97drexelgrad's Avatar
Cruise control has a bunch of different components that could caues it not to work. Many of the times it is a faulty brake light switch on the top of the brake pedal.. If it moves out of adjustment/alignment, the car/truck thinks that you are applying the brake and shuts off the cruise control. There is usually 2 switches there.
If it isnt them, then it could be a faulty cruise control module, a bad switch on the wheel or stalk, problems with the Powertrail Control Module, a shorted or broken wire anywhere in the system etc... hopefully it is just a blown fuse or a loose switch on the pedal- Good Luck
lortech
13
Mar 7, 2014 01:11 AM
pdub427
Aug 18, 2010 12:02 AM
Roctheunruly
Mar 8, 2010 07:32 PM
Mike D
Mar 4, 2009 06:33 PM
newfizzy91
Aug 24, 2006 12:25 AM
