I need help guys!!
Old Apr 25, 2010 | 07:08 AM
  #11
acnas's Avatar
I dont see why you cant tie it into another 12 volt source as long as it has 12 in start, run, and on. Not sure if you will be in the 2nd gear start until the code clears?
Old Apr 27, 2010 | 10:02 AM
  #12
tasutt2009's Avatar
possible VSS (vehicle speed sensor)
Old Aug 27, 2010 | 03:34 AM
  #13
fracturedpsyche's Avatar
my 95 c 1500 just started doing the same thing last month! i had a power steering leak, but the issue got worse after fixing the leak...i think the fluid shorted something out?? did you ever get this resolved for you truck??
thanks
Old Aug 27, 2010 | 12:49 PM
  #14
anything-with-a-motor's Avatar
check your ground to the computer and the ignition something might just be shorting out, possible a wire is just grounding out on something and needs to be adjusted.
Old Aug 28, 2010 | 11:09 PM
  #15
chrisbmo2000's Avatar
No you can not tie it to another 12 volt source without switching it!!!!!!!!!
dougo83
25
Nov 9, 2010 08:23 PM
opadilla
Oct 15, 2009 08:20 PM
wulfdog
9
Jul 29, 2009 02:16 AM
93GMCK2500
Sep 26, 2007 10:56 AM
