idk what to do my trany is sliping
Old Mar 24, 2008 | 01:35 AM
1997 chevy's Avatar
Default idk what to do my trany is sliping
should i rebuild?
get new one?
get used one?
its a 97 and i just changed my rear end man my truck is f**ked up
Old Mar 24, 2008 | 09:36 AM
04BLKCHEVY's Avatar
Default RE: idk what to do my trany is sliping
I would go for the rebuild. Mine as well put a shift kit in there. My cuz blew his tranny and did the shift kit as well and made a big difference.
Old Mar 24, 2008 | 09:44 AM
jcbst12's Avatar
GENERAL QUESTION: Mine was taking too long to shift between 3rd and 4th. So while under power it felt like a slip, but when under hard acceleration it shifted fine. On mine I think this has to do with my programming. It is set up to pull like a monster at low rpms and then lean out a little and advance the timing under hard acceleration and higher rpms.
I think by not having to press the pedal as hard to get her to go the truck "loosens up the shifting" thinking its under less load than it really is, like when you just cruzin along. I believe this is true because the shifting pressure and timing is based off of load and throttle position.
So the point Im getting at is if I programmed the truck to shift quicker and harder (slightly not like a ton more) it should be ok right? Also, how does programming the truck to shift compare to having a shift kit? You can adjust line pressures and quicker shifts with the programmer for every gear. Is this kinda the same result as a shift kit?
Quicker shifts and firmer shifts are better because there is less "slip" between gears, right?
Old Mar 24, 2008 | 11:54 PM
chevy112488's Avatar
i'd go witha rebuild and a shift kit as well... no sense in buying a new one its more expensive unless you want a built crazy one
Old Mar 25, 2008 | 08:48 AM
jcbst12's Avatar
Nevermind on my question. I got the long shift problem resolved by playing with the shift times. But now I have the clunking back when I start from a stop. I guess its time to grease the yoke again.
Old Mar 25, 2008 | 11:49 AM
rxsteven's Avatar
If you want a beter shift you'll want to go with a shift kit and Corvette servo 12 bucks on Ebay. If you want a new one check these out I plan on getting one when I get home
http://finishlinetrans.com/store/index.php?cPath=1_22
frankie1
Silverado/Sierra FAQs
May 5, 2011 12:51 AM
bbwalker
Apr 28, 2008 09:40 AM
infrared
Apr 9, 2008 02:43 PM
1997 chevy
10
Mar 29, 2008 12:13 AM
cosmo1
Oct 27, 2007 06:12 PM
