Instrument Cluster Change
Old Jan 22, 2008 | 04:56 PM
HSV_Madman's Avatar
Default Instrument Cluster Change
I am going to be taking my dash apart to change instrument clusters soon. Can anyone give me tips to removal of the bezel without breaking anything :-)
Old Jan 22, 2008 | 08:14 PM
stopspazinout's Avatar
Default RE: Instrument Cluster Change
what year?
Old Jan 22, 2008 | 09:15 PM
HSV_Madman's Avatar
Oops!
1999 Z71
Old Jan 22, 2008 | 09:20 PM
seb37's Avatar
Just read the post about the LED Dash Lighting a couple of post down from yours
Old Jan 22, 2008 | 09:28 PM
jcbst12's Avatar
Drop the steering wheel all the way down. Pull the shift lever down into 1st. (You'll need the key) Pull the dash front cover off by pulling gently at the edges. There is four bolts holding the intrument cluster in the dash (maybe more but Im pretty sure its four). Gently pull it forward and try not to smack it off the steering wheel. Don't pull too far as you will need to disconnect the wiring harness. Now you can pull the back off the cluster to access the bulbs.
FYI: If you have bulbs out try cleaning the contacts on the board, I had two out and now they work.
GTAViper
Mar 13, 2011 09:45 PM
oldchevylover
Dec 14, 2009 01:08 PM
jstill
Dec 12, 2008 02:31 PM
HSV_Madman
Jan 30, 2008 09:14 PM
xxcbr
Aug 21, 2007 12:23 PM
