Lights
does somebody has a diagram, or can tell me how to wire driving lights,so they come on with the high beams,but with a separate switch so i can turn them off ?
2005 GMC 2500 HD 6.0 4X4
thanks and merry christmas to all.
What type of lights are you planning on splicing into the high beams? If they are over 100 watts, you may not want to do this. Over time it could cause your light switch to burn out as it is not designed for that much wattage. Your best bet is to wire them to a separate switch. I did that once and also had it tied into a switch, over the course of 6 months it destroyed the switch with heat (partially because I used a switch not rated for the lights) and it caused my headlight switch to burn up.
dimmuborgir6nik6
21
May 12, 2023 03:58 PM
Shorted
Jan 4, 2011 09:22 AM
aub1027
Jul 20, 2006 10:25 PM
