No brakes after changing just rotors..:(
Old Nov 24, 2011 | 02:23 AM
guimond47's Avatar
Exclamation No brakes after changing just rotors..:(
Hey guys i ended up having excellent brakes , my rotors were worn out so i changed them and now my pedal is very bouncy and soft . My brake pedal has no pressure what so ever . I dint change any calipers or anything to mess with the braking system.. All i did was push in the pistons of the calipers in to fit on the new rotors in front thats it . Now no brakes ..:/ what u guys think i need the truck asap too soo help would be appreciated thanks guys
Old Nov 24, 2011 | 08:16 AM
Make sure you didn't blow a seal or hose when you pushed in the pistons.
Old Nov 25, 2011 | 05:48 AM
duby55's Avatar
Default Stuck piston
I had a piston stick after replacing the pads causing a similar reaction. I replaced the caliper, that took care of the situation I had.
Old Nov 25, 2011 | 08:33 PM
Old Blue 80's Avatar
Check the brake pads. The pads might be worn uneven and with the new rotors it's creating a gap. I have had 2 cars with this same complaint. Replace the pads and it should be perfect.
Old Nov 27, 2011 | 10:00 PM
ALOD's Avatar
Don't know what truck you have, but during part of my research on my brake problem , I was told by 2 mechanics that if I pushed the caliper pistons back during a pad change, especially if I was aggressive when doing so, I may have damaged the ABS unit. I don't know all the symptoms of a bad ABS module, so it may not be that at all. That is just my 2 cents.
markbark22
11
Oct 21, 2014 10:37 AM
raddroxx
Dec 26, 2012 08:24 AM
Caseycourtney80
Aug 15, 2011 10:17 AM
knoxy
May 14, 2008 09:51 AM
SouthBayZ71
Sep 4, 2007 12:42 PM
