no start 2003 silverado
Old Mar 7, 2011 | 11:22 AM
pmarc's Avatar
Default no start 2003 silverado
Turning the ignition starts all the accessories.. lights, door open bell, cd player but doesn't come close turning over the motor.
Yesterday had no problem and the temp is mild here: 45-degrees
Battery has been replaced I think less than 2 years ago. I wiggled the contacts - nothing. No lights were left on last night.
Does a battery drop so quickly with no warning? Drove truck about 45 miles yesterday.
Old Mar 7, 2011 | 11:41 AM
RUFFNECK4LYFE's Avatar
When you turned the key and none of the lights dimmed and your all your wires have good contact, your starter solenoid might be bad.
Old Mar 7, 2011 | 01:54 PM
pmarc's Avatar
Default ok
Suppose it could be the alternator also?
How can I check for which component is bad if I have no electronics tools?
Old Mar 7, 2011 | 02:53 PM
Well a cheap multimeter could help you show how much the battery drops with load. Charge the battery and see if it starts. Get a multimeter and start it. Battery should have around 12 volts. Alt should have around 13.6 to 14.4 volts when the motor is running. If the battery drops volts big time like to 7 volts when you start it then it could be bad.
Old Mar 7, 2011 | 08:17 PM
pmarc's Avatar
Default next
Jumped the battery, then ran truck 18 miles. Turned it off, then attempted to start immed after. Zip.
Anyone know what the starter solenoid looks like and where it is, for Chevy 2003 Silverado 1500 ?
Old Mar 7, 2011 | 09:45 PM
It sits on top of the starter which means its attatched to it. A whole new starter is what ya need.
Old Mar 7, 2011 | 10:00 PM
pmarc's Avatar
ok thanx.
Old Mar 8, 2011 | 06:49 AM
I would take it to an auto parts store and have them check the battery just to be 100% sure. It's free.
Old Mar 8, 2011 | 02:14 PM
pmarc's Avatar
Default fixed
It was the alternator and battery.
rowekmr
Jan 4, 2011 08:25 AM
izod
Feb 6, 2009 01:38 PM
DamnYankee
Vehicles for Sale
Jan 16, 2008 07:54 AM
kfleeman
Oct 5, 2006 01:09 AM
mikejums
Sep 7, 2006 09:39 PM
