OK WHAT is this and what is its function?
Old Apr 21, 2009 | 09:30 PM
chrisbmo2000's Avatar
Question OK WHAT is this and what is its function?
While messing around under the dash today repairing some minor issues I ran accross this "thing" laying next to the steering column attached to nothing more than 2 wires.....I found where it goes and reattached it. It goes where the shift cable attaches and then attaches to a stationary point on the column so the rod moves when you shift along with the cable.....is this the detent adjustment (there is an adjustment on the back side..........but I doubt it is detent).....I did not have time to run it up the street to the GM dealership today to find out what it was.........so............WHAT IS THIS BLASTED THING AND WHAT DOES IT DO????????????????
Old Apr 22, 2009 | 05:18 AM
Ummmmmmmmmmmm
Old Apr 22, 2009 | 02:21 PM
That is what is called a Brake Transmission Shift Interlock Solenoid. It basically is the piece that makes sure you have your foot on the brake when taking the truck out of gear. It also prevents the key from being removed from the switch unless the truck is in park.
Old Apr 22, 2009 | 08:47 PM
that makes sense thanks alot
Old Apr 22, 2009 | 11:33 PM
dmccartyfan's Avatar
Odd that you were still able to shift out of Park with it lying there disconnected. How'd THAT happen???
Old Apr 23, 2009 | 07:45 AM
with it disconnected it could not stop the shifter from moving....as far as how that happened....who knows could have been like that since I bought it
Old Apr 23, 2009 | 10:30 AM
98white5.0's Avatar
AHA! So that's why my truck will shift out of park without the brake.
Old Jan 13, 2010 | 02:21 PM
wlfent1597's Avatar
finally some one posts on the "can't get it out of park" subject
I'm changing the brake light sw because I thought that was the
problem, but can't access it enough to even get the clip off. do
I need to remove something else? Is it the same thing as what
you referenced in your post?
Jack Rockwell
Mar 25, 2015 12:21 PM
redbone
Nov 2, 2009 07:28 PM
EGT1
Oct 23, 2009 08:03 AM
hawks
Oct 7, 2008 03:15 PM
rxsteven
Street/Strip
22
May 26, 2008 11:33 AM
