Questions about after market rims
Old Jul 7, 2009 | 04:29 PM
captmick's Avatar
Default Questions about after market rims
So I put a set of 24 inch rims on my truck and I have to say it looks really bad ***. But im having a few problems and wanted to see if anyone could help.
The first problem is the front wheels rubbing up inside the wheel well. It, isnt too bad, and they only rub when I turn hard, and most of the rubbing happens in the back side, as opposed to the front fender.
Second, the tire light is on inside the car. I suppose its because they are just more massive wheels. Is there a way to bypass this?
Thanks for your time guys
Old Jul 7, 2009 | 05:51 PM
1993GMCSierra's Avatar
You didn't state your year, but seeing how you mentioned the tire light, I assume it's newer than 2004.
1. You need to lift the body say....2", to rid yourself of the rubbing issue.
2. Unplug the bulb.
Old Jul 7, 2009 | 07:04 PM
If it is rubbing something minor you could get in there and do some trimming. The light is due to your factory flat tire sensors, thay should have been removed from your old wheels and installed in the new ones.
Old Jul 8, 2009 | 11:44 AM
captmick's Avatar
Its an '09. Thanks for the input! Ill have it done
Old Jul 21, 2009 | 05:49 PM
kokain00's Avatar
most of the time you can take a torch and heat up (not burn) the wheel well housing and then push it in with a block of wood or something. You can usually gain a 1/2" or so (just enough to stop the rubbing).
808silverado
Aug 15, 2010 03:54 AM
workford
May 24, 2010 08:13 AM
farmboy91
8
Jan 24, 2010 08:21 PM
wanewbie
May 4, 2008 09:06 PM
