rotors
Old Mar 28, 2008 | 06:37 AM
revo25basher's Avatar
Default rotors
i ave a 1995 gmc serria with disc brakes on the front and drums on the back. i need to replace the rotors in the front but should i put new pads while i am at it to. Should i do anything to the drum brakes or just leave them for now. thank you
Old Mar 28, 2008 | 09:05 AM
jcbst12's Avatar
Default RE: rotors
Personally I would do the rotors and pads while you have it apart. Why not right? As far as the drums go, make sure your shoes aren't cracked, no hotspots, and makes sure there is a good amount of "the pad" left. Make sure there is no brake fluid, broken springs or missing parts. (Compare the two sides, make sure they match). If all is good and your e brake works ok, then just put the drums back on and leave em go.
Old Mar 28, 2008 | 04:41 PM
rxsteven's Avatar
Default RE: rotors
Go with new pads for sure! your old rotors might have worn them unevenly if so it might wess with your new rotors.
Old Mar 29, 2008 | 08:30 AM
Default RE: rotors
okay thats what i thought that i might as well if i got it apart. thanks
stopspazinout
14
Feb 26, 2009 09:13 PM
bluepony65
Apr 22, 2007 03:03 PM
8.1_HD_2001
Mar 14, 2007 11:39 PM
tundra2002
Nov 8, 2006 09:25 PM
Scott
Sep 13, 2005 11:01 PM
