silverado engine swap help
How's it going everyone, ive got a 1999 chevy silverado 4x4 with a 4.8L in it performance wise i put straight pipes on in and a intake and that all. I want to do something to get some more serious power for when i add bigger tires. I looked into a super/turbo charger and they are all in the 3 to 6 grand range so i figured it would be smarter just to put a bigger and newer engine in so i dont blow anything since my truck has 120,000 miles on it. Any suggestions on engine and transmission combinations to do?? any advice will help thanks
You can find a 6.0 lq9 pretty cheap at a junkyard with tranny for bout half of what that supercharger will run. For another $1000 a cam for that motor with a tune will add another 120lbs. of torque. My midly cammed 5.3 is around 360 hp. Headers are another 3 bills. All this easily puts you in the 420hp range. The supercharger will add about 125 to the 4.8, its too limited.
Check this guy out, stock bottom end junkyard 6.0 with cam, heads, tranny work, and spray, runnin 10's in his 95 ext. cab!
wow that is impressive and thats exactly what i want 400hp without a power outer, ive been doing a lot of online research and i found a 2007 Chevrolet Trailblazer SS LS2 Engine with Auto Transmission and AWD. Do you think that the AWD will work with my 4X4? How do you think it will bolt up?
monty2k04
Aug 4, 2013 07:26 PM
