Steering issue - clunking and rubbing/groaning sound
Old Aug 29, 2007 | 06:49 PM
wareagle's Avatar
Default Steering issue - clunking and rubbing/groaning sound
I have read a good many posts about the known issue with low-speed steering on the 1500's that manifests itself with a clunking under the hood that can be heard and felt in the steering wheel. As I understand this, the fix to this is either temporary (lube) or permanent (replace the intermediate shaft). My question is this, I have the symptoms listed above but also get a moan/rub sound in low speed turns. Does this sound like a related issue? Also, I have read that a lube on the affected part(s) will run about $90. How much should I expect to spend for the replacement of the shaft for parts/installation? Thanks...
Old Aug 29, 2007 | 07:52 PM
stopspazinout's Avatar
Default RE: Steering issue - clunking and rubbing/groaning sound
should be covered under warranty if you still have warranty
Old Aug 30, 2007 | 02:37 AM
Argon's Avatar
the shaft is 90 dollars....a lube kit about 15...its not too hard to do
Old Aug 30, 2007 | 11:49 AM
popo's Avatar
argon is this some thing that i can do at home? I have tons of tools and a pretty good knowledge of trucks.
Warlord43B
Aug 10, 2011 04:33 PM
larry posh
Apr 2, 2010 01:24 AM
dakota01
Aug 1, 2008 01:03 AM
wernettejr
Feb 14, 2008 08:00 PM
Giz03Z71
9
Dec 9, 2006 02:52 PM
