Still knockin and it sucks
Old Jul 29, 2007 | 08:39 AM
superddd's Avatar
Default Still knockin and it sucks
OK - I had autozone read the code and it said I had a bad knock sensor. Had a shop replace both sensors because I didn't have time. Engine light came on again later that day and had it read again. Says I'm still knockin and that I have low voltage coming from the sensors. Called the shop and the dude told me that the motor was probably knockin cause I'm still on factory wires and plugs. Did a tune up yesterday minus the fuel filter and reset the engine light (unhooked bat for a couple hours). Sure enough - still came on.
What do I do now???? Do I need to take it in for the injectors? Could it be bad gas? Please help!?!?!?
Thanks.
Old Jul 29, 2007 | 10:25 AM
Argon's Avatar
Default RE: Still knockin and it sucks
did the shop diagnose it?..if so,they need to fix it.
If you diagnosed it,and just told them to replace em..well..
Anyway...did they replace both?
did they replace any rusted connectors?
Do they have experience in this area..sounds like they don't...cuz it would be knocking its *** off to set a code.
of course,a cheapie part from autozone could be bad....but I'd bet on a ****ty connector..
Also..if you drop a new knock sensor on concrete,its ruined....hopefully autozone does not know that.
Old Jul 29, 2007 | 12:45 PM
superddd's Avatar
They're autozone sensors and I had them both replaced at a local shop that usually does good work. One was a rusty piece of crap and the other looked OK but I had them replace them both. I don't know about connectors or anything like that. The motor is running fine - in fact I could feel a bit of a differece from the new plugs and wires yesterday. I don't know about the connectors.
Thanks.
Old Jul 29, 2007 | 12:56 PM
Argon's Avatar
The rear sensor gets crusty...if it were really corroded,it needs a new pigtail connector...then silicone around the boot to keep water out of it..
Old Jul 29, 2007 | 08:42 PM
racethisz71's Avatar
maybe the knock seonsor is picking up detanation is the truck pinging or making any noise
Old Jul 29, 2007 | 10:28 PM
superddd's Avatar
Thats what the dude at the shop told me and said I should give it a tune-up. It would ping a little on heavy pulls or when it was on the floor at higher RPM - but I put it on the floor from a dead stop yesterday after plugs/wires and it wouldn't ping at all. It actually felt a little stronger than before. The trucks running perfect from what I can tell. I'm guessing I probably got jacked up on the new sensors.
Old Jul 30, 2007 | 06:05 AM
Argon's Avatar
its probably the connector..if 1 was crusty and the same connector was put back
sandjunky
Mar 9, 2011 10:22 AM
pst1572
11
Aug 18, 2010 12:08 AM
Mr_Shamrock
Jun 2, 2010 05:39 PM
bad2006z71
10
Apr 7, 2008 01:17 PM
jcbst12
Oct 16, 2007 07:54 AM
