Transmission cooler ??
Old May 22, 2009 | 05:33 AM
shmee's Avatar
Default Transmission cooler ??
I have a 2001 silverado which was not equipped with towing package.....i've been told that even though my truck wasn't equipped with towing package, that it still may have been equipped with a transmission cooler......without taking all the shrouds off around front of the engine, i see some sort of a radiator in front of the engine rad........would that be a trans cooler or maybe something related to the A/C system??
Old May 22, 2009 | 10:28 AM
goldylux's Avatar
yes, the rad infront of the engine rad is related to thr a/c system...
IF ur truck has a tranny cooler, it would be located infront of the a/c cooler.
it would look similiar to this...
http://www.cadvision.com/blanchas/54...erOldStyle.jpg
Old May 22, 2009 | 03:32 PM
chrisbmo2000's Avatar
lets clarify a little bit you are refering to an external cooler right? because ALL automatic vehicles have a cooler just not an external one.
Old May 23, 2009 | 09:34 PM
timber74wolf's Avatar
I agree with chrisbmo2000... are you referring to an extternal Transmision cooler?
Old May 24, 2009 | 07:41 AM
DamnYankee's Avatar
The radiator is closest to the engine and the AC condenser is in front of the radiator. The radiator has a built-in trans cooler on the passenger side.
Old May 24, 2009 | 10:45 AM
RUFFNECK4LYFE's Avatar
The external cooler should be sitting right behind your bowtie logo on your grill. It runs through the radiator first then through this cooler, which I dont think it is enough to cool it. I added a bigger one to mine.
Old May 24, 2009 | 06:27 PM
HaHa that just made me think of my "yonger" and more inventive days.............I once took a A/C condenser cut the ends of the hoses and used it as a tranny cooler.....you want to talk about doubling the fluid capacity and keeping a tranny cool. LOL that was on my 78 C10.
Old May 25, 2009 | 12:19 AM
Lol. Dam thats the way to do it. And I had a condensor laying around. I shoulda done that!!
Old May 25, 2009 | 08:49 AM
Is there a connection setup that will bolt into the stock lines so some one will not have to cut the stock lines in order to add an external tranny cooler?
Old May 25, 2009 | 11:04 AM
If you get rid of the stock cooler, I believe those connections will fit into some of the aftermarket coolers. So basically just switching out to a bigger one.
