Water issue?
Old May 26, 2011 | 03:00 PM
gmc newbie's Avatar
Default Water issue?
Hi all,
So I came home from a couple of weeks away, and the sierra had a hell of a time starting in the rain(it had rained for 2 weeks straight, and wasn't run at all). Got her going, no issues until a couple of days ago. It had rained overnight, and wouldn't start in the a.m. After work, I fiddled around , checked out the battery, fuel system etc, no problems. Noticed the engine was incredibly damp with water/condensation. Dried it off, no issues, she started running after a lot of cranking her over.Took it to work the nest day, no problems. Last night, really wet heavy fog, and same thing, the truck wouldn't start. Left it in the sun all day, and lo and behold, starts right up, no issues.
Has anyone had the problem?
Is it a distributor cap issue ie- a crack in the cap that moisture is getting into?
Thanks all!!
Old May 26, 2011 | 03:50 PM
Thats the first thing I would check (distributor cap).
Old May 27, 2011 | 11:26 AM
GM Customer Service's Avatar
Originally Posted by gmc newbie
Hi all,
Thanks all!!
I’m sorry to hear about the concern you’re experiencing with your Sierra. I see Mr. Shamrock had a suggestion for you… has your dealer had input on this at all?
Thanks,
Laura
GM Customer Service
Old May 28, 2011 | 05:04 PM
gmc newbie's Avatar
I took some time this afternoon and started tinkering away on the truck. Popped off the distributor cap, took a good look at it and the rotor button. No issues there. Turns out it was a bad spark plug wire from #6 cylinder. Changed the plugs and wires, and the old girl sounds good now. Thanks to Mr. Shamrock for the advice.
Old May 28, 2011 | 05:30 PM
cubpak89's Avatar
glad to hear you fixed yoru problem if your plug wire was bad i would go ahead and replace all of them just to be on the safe side
Old May 31, 2011 | 08:13 AM
I’m glad to hear you were able to take care of the concern yourself! Let me know if you need anything in the future.
Thanks,
Laura
GM Customer Service
In2Trux
Apr 19, 2015 08:50 PM
roadhouse1301
Jul 29, 2006 03:19 AM
no fear
Jul 10, 2006 09:57 PM
KS Z71
Jan 27, 2006 04:19 AM
ardvaark
Jul 11, 2005 06:12 PM
