Sponsored by:
Sponsored by: Kumho
86 electrical problem...
Old Dec 7, 2008 | 07:30 AM
bigred86's Avatar
Default 86 electrical problem...
i have an 86 f-150 with a dumb problem.. My taillight socket was bad, causing my signal lights not to work, due to the fact that there is a ground wire going into the socket. I replaced it. Now, the bulb acts as if it isnt in there all the way. If i take the taillight off, take out the bulb and push down on it, everything will work. but as soon as i take pressure off of it, only my taillights would work. A little help please
Old Dec 11, 2008 | 02:23 PM
TruckTrainHorns.com's Avatar
Default RE: 86 electrical problem...
Little confused about your problem..Is it grounding out?
Old Dec 16, 2008 | 06:43 AM
TRuckster's Avatar
Member
Try to check on loose wiring...
This may have cause your problem...
Or you can also check if the bulb is still fine...
sickshoesbrah
Mar 9, 2007 06:26 PM
chevyguy#1
Feb 25, 2007 04:45 PM
Mcfish
Nov 30, 2006 12:46 AM
quadracer
Feb 16, 2006 08:41 PM
chrisselfz71
Nov 15, 2005 09:36 PM
