Clunking noise
Old Jul 29, 2010 | 09:26 PM
fatrp's Avatar
Default Clunking noise
Hello! I am new here i just purchased a 1996 F350, crew cab, 2wd, V8 with 81K on it. It runs and drives great! The problem is that i have a clunking noise in the truck somewhere and am hoping there is someone out there that can lead me to the problem. It is mostly when driving around in it over the bumps and rougher roads, there is sometimes a squeak when turning and after the turn, and the a clunking noise in the drivetrain somewhere. I changed out the sway bar bushings frnt and rear as they looked worn out, check the ball joints and they seem tight, the u joints seem good.... any one out there have a clue what it might be? Thanks in advance.. Scott
Old Aug 27, 2010 | 04:17 AM
shaneo's Avatar
could be spring slap. the front springs slap together when you hit a bump. try putting a piece of rubber between the two pieces. Mine does it
richardlh3
8
Jan 26, 2023 06:33 PM
vjjf1960
Mar 15, 2011 07:32 PM
rollingthunder
Feb 3, 2009 06:58 PM
Giz03Z71
9
Dec 9, 2006 02:52 PM
Chevyvehc
Nov 7, 2006 08:17 PM
