F250 Auto Hesitation
Old Apr 19, 2010 | 04:59 PM
notwf250's Avatar
Default F250 Auto Hesitation
Hello all,
Just bought a 93 250 XLT 5.0 V8 Auto. There seems to be a slight hesitation between 1st and 2nd gear. If I floor it I can feel the hesitation... if I start off slowly then I don't get any. Prior owner said he had the truck for 3 years and it has done the same thing since he bought it without it getting any worse. That's what makes me think the transmission is fine, figure if it's done the same thing for 3 years without the trans getting worse that its got to be something else.
Any clues????
Thanks all,
Wes .... new F250 Owner
Old Apr 19, 2010 | 06:12 PM
bradsharp's Avatar
Member
Check the transmission fluid. Make sure its still good and not getting low.
Old Apr 19, 2010 | 06:56 PM
notwf250's Avatar
ya that is fine... been like this for about 3 years... wondering if running seafoam through my whole system would be a good thing
Old Apr 19, 2010 | 08:06 PM
bradsharp's Avatar
Member
How many miles does the truck have on it?
Old Apr 19, 2010 | 08:40 PM
notwf250's Avatar
it has 276,000....
Old Apr 20, 2010 | 02:47 AM
Worf's Avatar
that is alot of miles on a trans, is it the orignal trans? If so has it ever been rebuilt?
Old Apr 20, 2010 | 07:12 AM
notwf250's Avatar
Hi, it is alot of miles I know, To my knowledge the trans is original... weird though how it could be doing the same thing and not get progressively worse. Is there a sensor in their that is getting gummed up?
Also is it cheaper now to take it to a transmission place and say rebuilt this or best to wait until it goes to have it rebuilt?
Thanks
Old Apr 20, 2010 | 12:34 PM
bradsharp's Avatar
Member
Normally when you buy a vehicle it is best to have a mechanic look it over before buying it. Also I wouldn't take the guys word about engine and transmission problems when buying one. Now for a rebuild, that will cost quite a bit. I would take it to a mechanic and let him look over it and explain what the symptoms are before you think about having it rebuilt.
Old Apr 22, 2010 | 05:59 AM
Mid-MO-Smoker's Avatar
this is a common issue with the e4od trans, the only thing you need is a shift kit which is less then $100, never run a trans slip stop in these trucks because snake oils will just make it worse. My 97 powerstroke does it so bad it misses the shift sometimes but i got alot more power then stock going threw it. Brians truck shop makes the best rebuild transmissions and he warenties them for 1 year no matter what power you make the diesel version is $4300 but that includes a 3 disc billet converter and all fluids for a bullet proof combo
jmh080630
Jun 30, 2010 11:04 AM
max
May 16, 2010 10:26 AM
outdoorxman
Jan 1, 2007 12:21 AM
bgibson11
Nov 24, 2006 04:51 AM
