97 Silverado distributor cap.
Old Jun 9, 2005 | 02:22 PM
DAMAGEINC97's Avatar
Default 97 Silverado distributor cap.
I have a 97 Silverado with a 305 in it, and it seems to destroy dist. caps. They always get wet inside. I have even gone as far as a new distributor to try to solve the issue. The truck only has 82,000 on it and only sees mild off road use. Any suggestions would be greatly appreciated.[:@]
Old Sep 15, 2005 | 01:07 PM
radioflyer's Avatar
Default RE: 97 Silverado distributor cap.
First of all. . . Rock On (I have the same truck)
Water in the distributor can be quite a pain. you may want to check for cracks or condinsation in the rear of the engine compartment. if this problem continues, you shoud check the ignition system. A diagnostic computer can help locate specific problems. A friend of mine sealed off hie electiral connections with silcone to prevent shorts and problems with condensation.
Good luck
tercub57
GM How-To's and Tutorials
May 2, 2014 11:12 AM
white_noyez
Jul 5, 2011 09:04 AM
Streakn
Automotive Parts Wanted
Oct 17, 2007 08:40 PM
LT102
Jul 13, 2007 04:14 PM
alpinebeers
Oct 27, 2006 07:15 AM
