Electrical problem
Old Aug 3, 2007 | 09:36 PM
PhilandhisTJ's Avatar
Default Electrical problem
OK, so I bought this 97 Chevy Silverado 1/2 ton EXT Cab truck. The head on the left bank was cracked from who knows what. It has a 350 FI engine in it (not TPI) and I tore it down, had the block checked and all the right stuff done. Slapped some new heads on it and Voila!, so I thought. I plugged everything in to the proper ports (so I thought), yet I have 1 plug still missing a home.It is round, not oval, with 2 prong ports. It part of a brach from the main harness along with both A/C plugs, coolant neck temp sensor, harness ground, both plugs for T/B and some funky thing next to the thermstat neck. It has got to be for the A/C because my clutch isn't kicking in but there are no more ports that I can see. Can anyone help me with this problem?
Old Aug 4, 2007 | 06:13 AM
Argon's Avatar
Default RE: Electrical problem
it goes ointo the BACK of the compressor...small..black....careful,the pins are DELICATE...don't force anything.
Old Aug 4, 2007 | 12:33 PM
where on the back, I already have 2 plugs in there, 1 by clutch and 1 by by hard hoses in the back.
Old Aug 4, 2007 | 12:48 PM
Argon's Avatar
Right on the ***..
You have THREE plugs...the clutch coil...the sensor (green) on the hoses...and hi-pressure cut-off....opposite end of the belt.....route the plug over the compressor,there is a "clip" for the harness on your right..and sort of follow the path of your upper hose....on the BACK of the compressor itself
Old Aug 4, 2007 | 04:29 PM
FOUND IT! was looking at it all along. thanks for the info.
Old Aug 4, 2007 | 09:15 PM
Argon's Avatar
cool..she chills now?
sickshoesbrah
Mar 9, 2007 06:26 PM
chevyguy#1
Feb 25, 2007 04:45 PM
Mcfish
Nov 30, 2006 12:46 AM
quadracer
Feb 16, 2006 08:41 PM
chrisselfz71
Nov 15, 2005 09:36 PM
