K-1500 Brakes
Old May 31, 2007 | 05:36 AM
lucky's Avatar
Default K-1500 Brakes
My 1992 Chevy K-1500 truck has ABS system. The brake light is staying on. I can reset this by turning the ignition off or unplugging the ABS module. Is it possible that the priority valve is sticking. there are no leaks. The brakes work fine while the brake light is illuminated. I have all new hydrulic hoses and tubing in the brake system as well as new front pads, disc, rear brake shoes and drums. I installed a servicable module for another K-1500 truck but the problem remains the same.
Old Jun 24, 2007 | 12:13 AM
stopspazinout's Avatar
Default RE: K-1500 Brakes
no, this light is for either the ebrake cable being pulled. or air in the brake lines.
Old Jun 24, 2007 | 06:55 PM
MrLM7's Avatar
Try bleeding your lines and see if it goes off..
glterpening
Apr 30, 2012 11:35 PM
Mosey
Mar 19, 2011 05:21 PM
hinchcliffe
Jun 24, 2009 11:54 AM
silverado05
Jul 23, 2006 06:35 PM
Spufi
Nov 27, 2005 09:14 PM
