miss or stutter 5.3 4X4 (106K)
Old Feb 28, 2011 | 05:48 PM
BMC's Avatar
BMC
Default miss or stutter 5.3 4X4 (106K)
had a slight miss or stutter between 45 & 55 MPH when at steady speed. Time to change plugs and wires any way so I did it this weekend. Now miss is worse and also happens when accelorating easily in the same speed ranges. Any Ideas??????????
Old Feb 28, 2011 | 06:09 PM
Are you getting any codes? Has the throttle body been cleaned recently, if not it is basically a free (besides a can of throttle body cleaner) preventative maintenance item.
Old Feb 28, 2011 | 06:27 PM
BMC's Avatar
BMC
no codes, no check engine
Old Feb 28, 2011 | 06:34 PM
Then if you haven't already I would clean the throttle body real good along with the IAC (which is also in the throttle body) and see how it runs. If it still is not fixed I would start testing the sensors.
Old Feb 28, 2011 | 06:38 PM
BMC's Avatar
BMC
Like speed sensor, o2 sensor, coils etc.
Old Feb 28, 2011 | 06:42 PM
BMC's Avatar
BMC
excuse me for being stupid but what is the IAC???????
Old Feb 28, 2011 | 06:53 PM
Idle Air Control Valve - it is screwed into the throttle body. Also a bad TPS (Throttle Position Sensor) could be going bad without throwing a code.
Old Feb 28, 2011 | 06:58 PM
BMC's Avatar
BMC
If I get some one to plug a computer into to it and make it duplicate the problem will that narrow it down possibly. I have a guy who has a shop and is pretty good but not cheap but I trust him!!!!!!!!!!
Old Feb 28, 2011 | 07:24 PM
If he knows what values to look for then yes he should be able to determine the issue. Good luck!
Old Feb 28, 2011 | 07:26 PM
BMC's Avatar
BMC
thanks for your help shamrock
nbaptist
Aug 12, 2009 06:45 PM
wellsc1
Oct 8, 2008 05:45 AM
slider
Jun 15, 2008 07:28 AM
rotndawg
Nov 26, 2005 10:34 AM
