tire question
Old Mar 19, 2015 | 11:56 AM
rfloydlewis's Avatar
Default tire question
new owner of 2013 silverado 1500 ext cab 5.3 v8 6 spd a/t etc
this truck came with 255/65/R17 tires
door plate says it should have 245/70/R17..
What are the consequences of this difference please?
Old Mar 23, 2015 | 12:25 PM
The first number, in mm, is the width of the tire.
The second number is the percentage of the width that is the height of the sidewall.
The third number is the diameter of the rim in inches.
essentially,
The tires on it are 10mm wider than stock
the height of the current is 255x.65= 165.75--- x2 =331.5 + rim
height of stock is 245x.70= 171.5--- x2 =343 + rim
the total height of the tire is 11.5mm less than stock.
This is so insignificant I would not worry about it unless you can feel the tires rubbing when you turn them all the way, which you shouldn't
Old Mar 23, 2015 | 02:24 PM
thank you for your prompt and useful reply
PostRelease
Oct 8, 2010 03:01 PM
BADAZZ_Dodge
Apr 26, 2007 10:41 PM
SILVERado02
Jun 29, 2006 02:52 AM
bjs2000
Mar 6, 2006 10:52 PM
Huckleberry
Jan 8, 2006 03:01 PM
