88 GMC sierra 4x4, running lights inoperative
Old Nov 4, 2011 | 08:30 PM
svcmangler's Avatar
Default 88 GMC sierra 4x4, running lights inoperative
I need help with my running lights. They do not work at all, with or without the headlights. The interior dash lights also do not work. Headlights work fine as do the brake lights, and signals. I checked all the fuses, and they are fine. I don't know where to go next. Anyone have any suggestions?
Thank you for any help you can offer
Old Nov 4, 2011 | 08:32 PM
I would check to make sure the switch on the dash is sending power.
Old Nov 4, 2011 | 08:33 PM
svcmangler's Avatar
how would I do that?
Old Nov 5, 2011 | 08:35 AM
Pull the surround that goes around the instrument panel where the switch is housed. Get a test light and make sure that there is power coming in to the switch (which there must be b/c your headlights are working). Then make sure when you push the button down to the first click that you have power going to a different wire. I am not sure the color but if you test them all (there are only a few there) there should a wire that gets power when the switch is pushed to the first click and then another wire (headlight) that gets power when it is pushed all the way down. Good luck!
Old Nov 6, 2011 | 08:35 AM
svcmangler's Avatar
Smile fixed..!!!
Thanks very much for your advise. It was right on, after I checked the switch, there are 7 pins coming out of it, and I found one of the pins had a bad connection. Once I fixed that, everything works the way it is suppose to.
Thanks again,
Old Nov 6, 2011 | 11:03 AM
Cool - glad it worked!!!
eviltouch89
14
Jan 6, 2014 09:16 AM
svcmangler
Nov 4, 2011 05:39 AM
Shorted
Jan 4, 2011 09:22 AM
carl
Jul 23, 2008 01:02 PM
judykevans
Aug 15, 2005 06:51 PM
