Chevy/GMC Heavy Duty Discuss your 2500 and 3500 Chevy and GMC pickups as well as the DURAMAX diesel and it's predecessors
2013 2500hd 6.0 I am STUMPED
Old May 1, 2026 | 08:40 PM
jefferz.smyth's Avatar
Question 2013 2500hd 6.0 I am STUMPED
Problem occurring no codes. When lightly accelerating sputters more pressure on gas sputter goes away. Get to speed of about 40 to 50 mph light on the gas sputter happens push harder on the gas goes away, also when in cruse control runs fine.
Ok here we go I have changed out all of the following with re-learns involved. 183,000 miles fyi.
MAF (Delphi), MAP (Delphi), entire throttle body(Delphi), all ac delco parts: coil packs, spark wires, spark plugs, trans fluid and filter full service, evap solenoid, fuel pump relay, new gas cap.
Alternator is pushing 14.5v, grounds are great, old spark plugs all same and perfectly worn, cold start is normal, no vacuum leaks(smoke tested), fuel is premium, idle is at 500 to 600rpm.
Give me a hint I am at the point of just changing out the fuel pump i am stuck.
Thanks
Mangle
May 30, 2018 06:03 PM
Etaomicron2
Jun 6, 2017 09:55 PM
denwayanderson
Aug 3, 2010 11:26 PM
Toolman
14
Jan 6, 2008 08:40 AM
thomas
12
Oct 20, 2007 11:35 PM
