BEARINGS!!!!!!!!?????
Old Mar 29, 2008 | 10:16 PM
scotwea's Avatar
Default BEARINGS!!!!!!!!?????
Truck Info: 1995 Chevy 1500 automatic- 2wd
Problem: humming/winding sound coming from rear of truck, I think. Thought it was the bearings, changed the front ones, test drove, SOUND STILL THERE!!! How do I change the rear bearings???? Or is it something else?
Thanks
Old Mar 29, 2008 | 10:51 PM
rxsteven's Avatar
Default RE: BEARINGS!!!!!!!!?????
My bud has a 95 also he had the same prob. he thought it was the bearings also. One day I road with him to lunch and I said sounds like your u joint is going and he said no its a bearing. He changed all 4 then the u joint. I just smiled at him. Im not saying thats your prob. but it worth a shot pretty cheap to.
Old Mar 29, 2008 | 11:01 PM
scotwea's Avatar
Thank you for the suggestion. I will take a look at the U Joint before anything else.
Old Mar 29, 2008 | 11:03 PM
Chevycowboy's Avatar
Id say the same. Mine just went out not too long ago.. The sound is very random and odd.. it's a cheap fix anways... good luck!
Old Mar 29, 2008 | 11:16 PM
scotwea's Avatar
Thanks. I was looking in my Haynes book andchanging the U Jointdoes look pretty easy to do.
Old Mar 30, 2008 | 11:32 AM
scotwea's Avatar
UPDATE- I justed called Napa to find out pricing for a u-joint and he asked me which one??? How many u-joints are there???? I think I've found 3? The sporatic winding/humming sound sounds like its coming from the back?
Old Mar 31, 2008 | 12:44 PM
04BLKCHEVY's Avatar
It could also be your gears in the diff? Just check your u joints if they are good? Make sure there is no metal on metal. The u joints make odd sounds. Mine whistled when they went bad and had metal on metal. If its the ujoint make sure you get the ujoint that is regreasable.
Old Mar 31, 2008 | 09:43 PM
You have 2 or3 different ones, I can't remember exactly. I just took them all off and drove another vehicle to the store to get em matched up. And make sure you replace all 4, just replacing 1 or 2 would be like changing 1 or 2 brake pads if you get what I mean. Also you will need to get a c-clamp type tool to remove them, and snap clip pliers. The frustrating part is fitting the new bearing caps in the drive shaft, and getting those little clips out. Hope that solves the problem. good luck!
Old Apr 1, 2008 | 08:48 AM
jcbst12's Avatar
It is either the U-Joints or low fluid in the rear diff.
scotwea
13
Apr 5, 2008 09:47 PM
scotwea
Mar 26, 2008 09:42 AM
tgalyean
10
Feb 15, 2008 09:29 AM
sknaffl
Mar 3, 2007 01:34 PM
Roadking666
Nov 12, 2006 02:19 PM
