knock censer?
Old Nov 18, 2008 | 11:15 AM
morrow63's Avatar
Default knock censer?
i have a late model 99 with a 5.3 and the check engine light came on i had the codes ran and it came up as the knock censer. But my motor has no knock to it at all, so ether i need a new one or it is lose and i have no clue where it is located.
Old Nov 18, 2008 | 12:32 PM
DamnYankee's Avatar
Default RE: knock censer?
The knock sensors are recessed in the valley cover under the intake manifold. If water gets in there they will corrode the sensors and screw the readings up. That would be my guess....it's a pretty common problem especially if you powerwash your engine.
If you replace them, run some silicone around the rubber seals.
Old Nov 18, 2008 | 04:42 PM
chevy112488's Avatar
what most likely happened is over the time of your trucks existence water has gotten into the foam padding they put over the knock sensors and they are completely rusted out, so now they aren't sending the signal to the pcm as they should. you'll have to pull the intake manifold and replace them. like yankee said put some sort of sealant on them when you replace them.
Old Nov 20, 2008 | 10:59 AM
morrow63's Avatar
well i haven't have the truck for too long and i bought it off of an old man, the check engine light came on a few hours after i pressure washed the motor for the first time and haven done it since
Old Nov 20, 2008 | 02:33 PM
DamnYankee's Avatar
If it cleared and doesn't do it anymore you should be fine.
Old Nov 20, 2008 | 06:19 PM
yeah if the light's off you're good.
ph34903
9
Oct 24, 2011 12:30 PM
txtravster
Jan 10, 2008 11:45 AM
08Z71
Dec 16, 2007 06:00 PM
superddd
Jul 27, 2007 02:09 PM
allamericanman666
Feb 26, 2007 10:59 PM
