Removing aftermarket chrome rocker panels?
Old Jun 28, 2007 | 07:19 AM
rak187's Avatar
Default Removing aftermarket chrome rocker panels?
I just purchased a used sierra and would like to remove the 6 inch aftermarket chrome rocker panels. Does anyone know how these are adhered to the vehicle? Is it just on there with double sided tape? How do you remove the adhesive without ruining the finish on the truck? Thanks in advance.
Old Jul 1, 2007 | 04:19 PM
stopspazinout's Avatar
Default RE: Removing aftermarket chrome rocker panels?
yes theyre attached with double sided tape. if you did it carefully you might be able to get it off with a razorblade perfectly otherwise youll have to spend some time getting the rest of the tape off. i dont suggest removing them as there is a decent chance of messing up the paint.
Old Jul 9, 2007 | 09:17 AM
sootjunkie65's Avatar
Those stupid looking things are usually attached with double sided tape, have fun taking them off, you'll most likely need to repaint.
Old Jul 10, 2007 | 12:14 PM
argomez75's Avatar
what up man. it might seem a little too late and don't know if you have removed them already. my bro has a '97. he had the rocker panels on them, the stock. pretty sure the aftermarkets are the same and have the double sided tape. don't do a razor blade. yank them off and get those industrial heat guns. once the glue of the tape start melting, use a plastic spatula to remove it. the spatulas that are used to apply bondo or the ones used to get the bubbles out of tints. you can use some regular gas to help remove the adhesive. they sale adhesive remover at auto part stores. it shouldn't mess up your paint. once off just give your truck agood wash and wax. no repainting is needed. since we experienced the same situation. fyi: we have 3 sierras in our household. '97, '03, and just added Jan. an '07. -peace
Edgard Molon Labe Kunhardt
May 23, 2015 06:59 AM
dream3wheeler
Jul 6, 2014 07:52 AM
MRC Chevy
Dec 20, 2013 07:16 PM
GeorgeO8
Jun 28, 2010 09:18 PM
KC03silverado
May 6, 2010 03:47 AM
