Ford Ranger/ Mazda B-Series Discuss the Ford Ranger and it's sister, the Mazda B-series here.
Hub noise
Old Feb 2, 2012 | 11:07 AM
broncswagon's Avatar
Default Hub noise
My friend asked me to pack the front bearing on their 1993 ford ranger 4x4.
when I removed the auto locking hubs, I laid them out and reassembled the exactly as they came apart.Not very complex at all. Now there is a clicking sound coming from both sides. And clue whats up with that. Did I miss an important step that wasn't obvious. The assembly was layed out perfectly and went together in the same sequence. The 4 wheel drive engages and disengages normally. Is it normal when you put the hub cover back on over the hub, the last 1/2 inch is spring loaded? Or is there suppose to be no resistance at all when installing the cover over the hub.
Before i packed the bearings there was not any clicking sounds coming from the hubs. Perhaps I didnt torque the bearings right?. Should be like any other bearing job right?
vinces2600
Dec 14, 2008 12:36 PM
tamarac
Apr 9, 2008 12:01 PM
jasonjmcgee
Jan 2, 2008 05:35 PM
sknaffl
Mar 3, 2007 01:34 PM
dm18k
Jan 25, 2007 11:01 PM
