Two questions for 78 Chev C-20
Old Nov 18, 2007 | 03:41 PM
hannajb's Avatar
Default Two questions for 78 Chev C-20
Hey all, Newbie Chevy owner here. I have a 78 Chevy C-20 with the 350, 2WD p/u. Good little farm truck, but there are a few things that I am curious about...
#1 - When I leave her alone for a week or so without starting, the carb and fuel lines seem to drain back to the tank. Or maybe the fuel is leaking out somewhere. Is there a check-valve that should be in there, or do you think that my old truck needs new fuel lines and the cracked, old fuel lines are "releasing" the vacuum on the suction side of the mechanical pump?
#2 - When she drives, the manual transmission is very noisy - sounds a bit like grinding, but not totally metallic... Not sure what to make of it. Suggestions?
#3 - When I turn the steering wheel all the way to one side or the other, there is a horrible squealing sound. I have filled the steering fluid, what else to check?
Thanks, all!
Josh
Old Nov 18, 2007 | 09:01 PM
Argon's Avatar
Default RE: Two questions for 78 Chev C-20
p/s belt I imagine on the squawl...
not sure about the tranny noise...better let a ytrans shop listen.
the drainback...yes,the pump should prevent that...but more common was the plugs in the bottom of the floatbowl would drip gas into the engine overnight
Old Nov 18, 2007 | 09:52 PM
hannajb's Avatar
Thanks for the advice on the P/S belt and tranny.
As for the plugs draining gas into the engine, is that something that will require a carb overhaul? While I am at it, should I replace the stock Rochester with an Edelbrock or Holley?
Thanks!
Old Nov 19, 2007 | 05:53 AM
Argon's Avatar
if its dripping,you need to replace the float bowl..so i'd repl;ace the whole carb..
i'd stay factory,but thats up to you
Worf
Feb 22, 2011 11:30 PM
wulfdog
9
Jul 29, 2009 02:16 AM
Jenners
22
Mar 20, 2009 10:07 PM
soundobsessed
Aug 18, 2007 10:46 AM
Danko
Vehicles for Sale
Feb 2, 2005 11:24 AM
