looking for some info
Old Oct 13, 2011 | 08:47 PM
  #11
No that isn't correct. If you turn the key on engine off it should go up to around 60 and not drop more than approximately 5 PSI in 5 minutes. This is just a rule of thumb so if it drops a little more I wouldn't worry, but down to zero isn't right. Is this when trying to start it or just with the key on. It could be bad regulator, pressure valve in the pump, or leaky injectors.
Old Oct 13, 2011 | 11:29 PM
  #12
NullHead's Avatar
That'd be a heck of a leak if the injectors weren't holding pressure ...
Definitely isn't supposed to be doing that.
Old Oct 15, 2011 | 07:08 AM
  #13
david06's Avatar
It drops to zero just when the key is on. If I try to start it the pressure jumps back up to 60. I can't seem to find the fuel pressure regulator. Does anyone know where it is located? It is not by the fuel rails at all and I do not see it anywhere else.
Old Oct 15, 2011 | 09:12 AM
  #14
It should be on the drivers side of the intake on the fuel rail...
Old Oct 15, 2011 | 05:02 PM
  #15
david06's Avatar
yea I wish it was but it isnt
Old Oct 16, 2011 | 06:07 AM
  #16
david06's Avatar
Any other ideas as to where it might be? I searched and searched but still cant find it. Is it possible that this truck just doesn't have one and if it doesn't then how is the fuel pressure regulated? Oh man this is really getting ridiculous but I will get it sooner or later. I really appreciate the help on this matter.
Old Oct 16, 2011 | 07:53 AM
  #17
Old Oct 16, 2011 | 11:01 AM
  #18
david06's Avatar
Thank you Mr_Shamrock that definitely explains why I couldn't find the regulator. after looking into the fuel pump further i found it is located there but now I am still stumped because I don't know why it wont start. So if you come up with any more thoughts please share them with me. Thank you
Old Nov 1, 2011 | 01:37 PM
  #19
joshstover69@yahoo.com's Avatar
lol there is a check valve in the pump also . dose it hold 50 psi running ? give or take
Old Nov 1, 2011 | 01:39 PM
  #20
if it only has one fuel line the reg is part of fuel pump ***.
saifeye
Mar 8, 2012 05:45 AM
nam6869usmc
Oct 10, 2007 07:55 PM
infinibot12
Jun 15, 2007 07:33 AM
CHEVY06
Mar 10, 2007 04:56 AM
fndngemo
Nov 20, 2006 11:20 AM
