performance motor
Old Feb 10, 2008 | 08:20 PM
  #21
smoke20's Avatar
Default RE: performance motor
Well I am not going to buy a different truck, just want to make this one fast. The SS will not work as I need the 4wd. SO looks like either the 502 or stroked 383 for simplicity. I have heard of the 383 stroker easily pushing 500 hp and still with decent milage. This truck also has to be driveable for daily driving and towing, but just barely. I will give a little to get alot.
Old Feb 10, 2008 | 08:25 PM
  #22
stopspazinout's Avatar
i always thought those largely built stroker 383s that had that infamous lope to them at idle would be cool to run into on a truck on the street. no body thinks big around here tho.
Old Feb 10, 2008 | 09:20 PM
  #23
smoke20's Avatar
I always think big. If you saw my business you would understand. I think a stroker is the way to go, and could you imagine a crew cab stroker? that would be bad ***!!
Old Feb 10, 2008 | 10:00 PM
  #24
lol exactly why i thought to bring it up first thing in this thread. the whole sleeper truck concept.... is just great to see a big *** truck with the ***** to back it up.
Old Feb 11, 2008 | 09:06 AM
  #25
jcbst12's Avatar
What about getting aGM performance 5.3 and using your factory PCM and wiring, then strap a Turbo to it or Supercharger? Remember when I was looking at that $1,500 (used) supercharger setup? They guy had an 2000 Silverado 5.3, ext cab, 4X4, with 38" tires on it. He said it would smoke HEMI's with it with a 3.73 gear ratio, but still get the exact same gas mileage on the highway as it did BEFORE the supercharger AND the 38" tires! Ok so take it a step further, start with a performance block, get the STS turbo kit (will put out more than the supercharger), crank up the boost as high as you want, then get a custom tune to tie it all together! I bet you could get 500 rear wheel hp without a problem. Might want to build the transmission up too, lol. That will leave you with enough "potential" to straap performance parts to it and bump it up whenever you get bored! lol. And you can also open the exhaust up without worring about torque loss. Thats what I would do. That way it will still drive like your truck does now, just with more power.
1994GMCSierraZ71
11
Mar 15, 2012 08:11 PM
bad2006z71
10
Aug 10, 2011 08:21 PM
Bagged out Chevy
Feb 2, 2006 01:55 AM
Sep 6, 2005 03:24 PM
beinc
Jul 17, 2005 11:13 AM
