Dodge/ Ram Heavy Duty Discuss the 2500 and 3500 Heavy Duty Dodge/Ram Pickups as well as the Cummins diesel.
Belts Squeeling on 24 Valve Cummins 5.9 when shutting down
Old Apr 5, 2011 | 10:41 PM
Blake's Avatar
Member
Default Belts Squeeling on 24 Valve Cummins 5.9 when shutting down
As the title states, the Cummins 5.9 liter 24 valve engine in my 2001 Ram 2500 is kinda stumping me as I'm new to diesel engines (never owned one before and got alot to learn). The engine belt (i suppose) squeels when the ignition switch is turned off and the engine is shutting down. It does not happen as the engine is being started, or as the engine is running at any RPM.
I've heard that its normal for this to happen because the engine has a high compression ratio.... but i have no idea, thanks in advance for any help yall!
Old Apr 6, 2011 | 10:53 AM
I have never made myself acquainted with the 5.9 Cummins yet but would tightening the belt and maybe treating it with some belt dressing out of the question?
Old Apr 6, 2011 | 07:43 PM
Blake's Avatar
Member
I'll deffinatly have to try the belt dressing, altho it may be in need of a new belt. The one thats on it seems to have quite a bit of wear on it and it appears to be cracking which could pose larger issues if not tended to quickly. Not sure how much replacing the belt will cost tho... hopefully not too much.
Old Apr 12, 2011 | 11:17 PM
Blake's Avatar
Member
applied some belt dressing the other day and it quietened it down a considerable amount but it still has a little chirp to it. not enough to bother with, if it begins to get loud enough to be a problem again i'll just replace the belt.
Old Aug 21, 2011 | 10:51 AM
dusturbd's Avatar
that is 100% normal on a 5.9 I have had 3 of them and they all do it.The motor stops fater than the belt can and it chirps there is a TSB about it somewhere but nothing to worry about
Old Dec 12, 2011 | 08:05 PM
Wiked's Avatar
yeah same thing with mine and my freinds
my belt tensioner is bad too so that has something to do with it too
Old Mar 6, 2012 | 10:29 AM
mydar's Avatar
nice stuff it would help me a lot thanks for the stuff.
Jamcousi9
Dec 26, 2018 08:24 PM
Dzj
Apr 19, 2010 05:32 AM
klr650goldwing
Feb 11, 2010 11:24 AM
taz
Feb 18, 2009 12:00 PM
bigdaddyred
Nov 25, 2007 03:29 PM
