strange sound in trans
Old Dec 27, 2007 | 12:31 PM
golferbrady's Avatar
Default strange sound in trans
i jacked up truck and put on jack stands and pulled drive shaft
it sounds like noise is coming from the tail shaft
i pulled the back houseing off and semms to be fine but
tail shaft has some play in it how much should it have (play)
Old Dec 27, 2007 | 01:00 PM
Argon's Avatar
Default RE: strange sound in trans
a fair amount...does the noise change when it shifts?
Old Dec 27, 2007 | 01:03 PM
yes it seems to be worse in 1 and over drive
it is a squiling sound of some sort
Old Dec 27, 2007 | 04:57 PM
Argon's Avatar
not good..1-4 are the same clutch...better hit the dealer or trans shop
Old Dec 27, 2007 | 06:34 PM
stll shifts the same but it makes that sound do u think that it is some thing broke i side if so sould i be able to pull pan off and see some thing in the pan
Old Dec 28, 2007 | 05:35 AM
Argon's Avatar
i doubt it..there is a 1-4 drum thats known to break..or its bearing...i'd get it checked out...
Warlord43B
Aug 10, 2011 04:33 PM
chrisbmo2000
Jan 27, 2009 10:14 PM
golferbrady
Dec 28, 2007 12:57 PM
ferg
17
May 3, 2007 02:49 PM
HotRod1451
Aug 20, 2005 12:04 AM
